Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Old (very ) Hotpoint , part required.
- This topic has 4 replies, 3 voices, and was last updated 20 years, 7 months ago by
iadom.
August 23, 2005 at 9:11 am #11505
ModeratorDon’t laugh but I have a long standing customer with a Hotpoint 18370 aged around 24 years ( the washer that is ). It still has the original black rubber door seal, pump etc. The drum, backplate & bearings are very sound. I fitted a Qualtex ARM 20 to this machine over 17 years ago and the armature bearings are now shot. The customer is insistant on me repairing this machine but the one problem I have is the old type motor. The hole in the motor end cap/housing is only big enough for the motor shaft to fit through, the early ARM 20’s came with a separate pulley that you had to fit with two pins after you had reassembled the motor. ( you had to saw off the pulley on the old armature)
All hotpoint gen & ARM 20’s now come with the pulley fitted so I cannot fit one to this machine.
All I need is the motor pulley end bracket with a hole that the motor pulley will fit through.
I will gladly pay all costs incurred.Jim.
August 23, 2005 at 9:38 am #145580cornwell40
ParticipantRe: Old (very ) Hotpoint , part required.
Will the end cap from a 161410or 161408 do?
If it will PM me you address and I’ll get one over to you.
Price of a :beer: if it’ll do
Tony CAugust 23, 2005 at 10:34 am #145581iadom
ModeratorRe: Old (very ) Hotpoint , part required.
That would do nicely, the size of the hole is all that matters ( oh matron ) 😳
A pity I am busy, I could do with a trip to the seaside.
Will PM you my details.
Thanks.
Jim.August 23, 2005 at 6:06 pm #145582Phidom
Might be a silly question but can’t you just drill the hole bigger?
August 23, 2005 at 6:28 pm #145583iadom
I don’t have a drill that big, however it would be an option to get it drilled out at an engineering shop, the pulley is much larger than the shaft and would really need a big drill and strong restraint to drill such a light piece of alloy.
I suppose an option would be to file it out but that would take some considerable effort.
I have one on they way thanks to cornwell40’s kind offer. 🙂
