old zan d/w
  • #23569
    streetlighter
    Hi all
    I have an old zan d/w the one with the 2 blue syphone tubes under the round cap, which will do the first fill but the p/switch wont reset when the water pumps out. (so heats empty 😯 )
    when I pull the p/pipe of the sump the p/switch clicks and some water comes out then i have fill again.
    Do you think I have a lazy p/switch or a problem with the sypone set up, I have cleaned it 6 times so far ? should there be any water on the pipe side if the syphone tube?
    Ta
    Paul
    #198615
    clivejameson
    Re: old zan d/w
    Hi Paul
    If the syphons were blocked then the port underneath the draining end of the syphons is prolly blocked too…if you look underneath you’ll see a small looped hose that appears to come out of the sump and double back into it, that’s where the problem will be 😉
    #198616
    streetlighter
    Re: old zan d/w
    Thanks for the quick reply clive on wayback there now to have another go.
    I will try that.
    Ta
    Paul
    #198617
    streetlighter
    Re: old zan d/w
    Thanks clive it was the loop of the sump
    Ta. again
    Paul
    #198618
    clivejameson
    Re: old zan d/w
    No probs Paul, always happy to help…have a happy Christmas 😀
