Oldish AEG
  • #41901
    don
    Please if anyone can help ?
    We have an AEG L16810 PNC 914601801/00 showing E40. Nothing listed in fault codes book / forum and nothing on TDS disk 😕
    Fault code appears when machine is set to tumble dryer mode.
    Don
    #271689
    Seamy
    Re: Oldish AEG
    E40 is a door fault, all 40’s (E40,E41,E42,E43) are in relation to door,
    Consumer will normally only get a E40 fault shown, but if you (the engineer) go into diagnostics & check fault register you should get a more specific code, eg E41,E43 etc
    10s water filling
    20s draining
    30s water pressure
    40s door
    50s motor
    60s heating
    70s temp sensing
    80s programme selection
    90’s PCBs
    hope this helps
    #271690
    don
    Re: Oldish AEG
    Thanks Seamy for the info :tup:
    I`ll post up the outcome for any future posters who may have the same problem.
    Don
    #271691
    don
    Re: Oldish AEG
    Seamy wrote:but if you (the engineer) go into diagnostics & check fault register you should get a more specific code, eg E41,E43 etc
    Hi Seamy or any other kind soul 🙂
    How is the configuaration access gained as our engineer wants to check PCB first?
    Don
    #271692
    Re: Oldish AEG
    Don’t you have the TDS disc Don?
    I have sent you a file, hope you have a decent BB connection. 😉
    don
    Re: Oldish AEG
    Hi Jim
    Thanks for the mail download, over 5mb no probs. I do have the TDS disc Jim but I couldn`t see it on the info for that model :rolls:
    Don
    #271694
    don
    Re: Oldish AEG
    don wrote:Hi Jim
    Don
    Sorted now thanks Jim, it was user error 😆
