Home › Forums › General Trade Forum › One for Alex – How to take the back of a Zanussi
- This topic has 11 replies, 11 voices, and was last updated 18 years, 10 months ago by
Dales-Electronic.
June 3, 2007 at 8:29 am #27833
Dales-Electronic
ModeratorNow that we’ve signed up to be a designated collection facility with John, it was with much amusement that we received this one with the first batch. :rotl:
June 3, 2007 at 8:35 am #215798A1TEC
ParticipantRe: One for Alex – How to take the back of a Zanussi
Why did zanussi not think of that idea? 😆
June 3, 2007 at 8:46 am #215799VillageIdiot2
BlockedRe: One for Alex – How to take the back of a Zanussi
Unbelievable 😯 😆
June 3, 2007 at 9:35 am #215800Alex
Fantastic. Makes me wonder what the guy managed to do given that small area.
Reminds me of the early Candy machines. They had raw edges like that as well. Their trainer (Mel Barff) used to say the foam around the edges were not there to prevent you cutting yourself, it is there to soak up the blood.
The irony with the Zanussi’s, you took the back off and 17 tub bolts were accessible from the front. Now after 17 years you can take the front panel off, and they no longer use bolts, welded tubs.
Alex
June 3, 2007 at 1:05 pm #215801Seamy
I once went to a washing machine Bendix I think & the guy before me had cut the complete side out of it with an angle grinder, removed the tub, did a bearing replacement job put it back together, welded side panel back on with arc welder (blew holes all through it). Painted it up & charged custemer £40. I removed coin from pump & was lambasted for charging £40…
June 3, 2007 at 1:19 pm #215802dpm
ParticipantWasn’t a farmer was it?
June 3, 2007 at 4:22 pm #215803Seamy
A “handy man” was how he was described…. :rolls:
June 3, 2007 at 5:44 pm #215804Goatboy
Bizzare! 😕 I wonder if it was repaired.
I must admit to doing something slightly similar to a new oven once :shutup: It was a slot-in single. I’d had it out of the packaging for 2 minutes, when I had to dent in the back, top corner because of a huge work-top backet 😕 Luckily I’m a great engineer, and I made sure it was all kosher!
Shhh, don’t tell!
June 3, 2007 at 11:24 pm #215805senseib
Where there’s a will there’s a way!
June 4, 2007 at 2:08 pm #215806wilf
once went to a 95 where the customer had installed the machine flush into a side wall by knocking a hole through into the coal house. made access to the pump easy once I had moved all the bricks. god knows what the council thought!!!!!!!!!!!
wilf
June 6, 2007 at 3:23 pm #215807effzedarr
Blimey Alex yhats going back,I remember being in that corse aswell.
June 6, 2007 at 9:43 pm #21580821rich33
ParticipantWilf
I used to have an old electron on my patch like that.
Front of the machine was in the kitchen. To get the rear you went out of the back door into the outside loo and removed a wooden cover and there was the back of the machine!!!!Rich
