The culprit is a SGS45E02GB/45 FD8411
Original fault was the drain pump running continuously.Solved this by replacing the control module BUT then we got the overfilling problem, replaced the impellor jug thingy and the fill valve but still the same, just fills until the red float activates the pump.
Interesting fault code appeared, 12 which according to Bosch technical is two fault codes added together =faulty module. So replaced module again also impellor jug to be safe, STILL overfilling! 😯
Checked wiring harness and connectors, no problems. Not getting 12 fault code now though, oh, i did program module on fitting 😉
Have i missed anything?
Thanks in advance
Ray
