Proline frost free freezer, working ok but fan not running.
There is no excessive ice build up on the evaporator and the fan is free running, this is as far as i got as i was there doing something else plus i was on a meter 😀
Would this be the fan or the electronickey bits?
Looking at the wiring diagram (it’s a Brandt by the way) the fan motor is supplied directly from the PCB so if the fan motor isn’t faulty it can’t be much else really.
Unless a faulty thermistor is causing the error, there’s two of them, described as temp probe and defrost probe.
The last 3 appliances with fault I have been to has turned out to be the PCB,You can check that there is or isnt power coming out from the PCB from the front at the PCB connections.
