Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › one for the smeg heads
- This topic has 9 replies, 3 voices, and was last updated 16 years ago by
funkyboogy.
March 30, 2010 at 9:03 am #53648
funkyboogy
Participantgot a pcb form dw1 410 , component marked q11 which lines up next to wiring plug c has blown ….
checked wiring dia to see where wiring from c connetor goes to , wires run to something they call vent …
any ideas what vent is ..
cheers ally …
March 30, 2010 at 9:26 am #316741Penguin45
ParticipantRe: one for the smeg heads
Dryer motor? Bottom of housing, l/h side.
March 30, 2010 at 9:29 am #316742kwatt
KeymasterRe: one for the smeg heads
You have mail. 😉
It’s a DWI410. 😉
The vent is most likely the dryer as that one, from what I can see, does the old fanned/vented drying trick through the grill.
March 30, 2010 at 9:48 am #316743funkyboogy
CHEERS GUYS ..
will check mail ..ally
March 30, 2010 at 10:15 am #316744funkyboogy
just had a look at service manual (ta k ).. cant see a blower component ,
i have ordered pcb, heater , dispensor , hopefully this will cure it ..
will update asp ..
ps any other info on what took out pcb appreciated …
March 30, 2010 at 10:22 am #316745kwatt
KeymasterLook at the bottom of the side chamber. 😉
March 30, 2010 at 10:37 am #316746funkyboogy
ahhh , see it now
cheers ally
March 30, 2010 at 10:40 am #316747funkyboogy
whats the chances that its this blower that has taken out pcb ,
dont know if im over analysing pcb ..??anyone had this b4 ..
cheers ally
March 30, 2010 at 10:46 am #316748kwatt
KeymasterDepends what voltage it’s switching, if it’s mains then possible, low voltage then I doubt it. Although, all things are possible.
The blower fan or heater should just be a simple continuity check to test so I’d start there. If the bits seem okay it’s probably just a resistor or relay on the board that’s been fried and taken out the track/s.
March 30, 2010 at 12:59 pm #316749funkyboogy
cheers …
not just pcb failure , been there.
im a bit of a fan for following pcb connector terminals to components usually leads to culprit,ive not been to this , so relying on avail info and failed pcb .. which i only got yesterday, after been lying around in eng van…
insu job , not dag ..just want to make sure all part covered for return
swine of a think to access etc ..ally
