Re: Only 1 of 4 heating elements working on Creda T622CW
Whilst there are four sections to the elements they are switched in banks of two. you should get two or four elements on, depending on the position of the High/Low switch. Live testing is something that is not advisable. or sensible, however, if you have the back panel off, it is normal to see only one element glowing for the very short length of time that it is safe to run in this condition. High/Low switch failure is uncommon, but not unheard of.
To be honest, a simple check with a multimeter or similar on this switch would suffice, without the need to test live with the back off.
You make no mention of actually checking the original elements for continuity with the correct equipment.
Please remove the plug if you intend to proceed further.
