Optimal water level
  • #102778
    Posi
    Hello,
    I have a Bosch with the FD number 9210 602123 (Bosch WAE 24271FF/32).
    I have the impression the machine is washing with little water. Usually, you see the water covering a third of the glass door.
    I wonder if I need to do something, and if so, what?
    #490430
    No, you don’t need to do anything that is very much normal on virtually all modern machines.
    kaibart
    Given that machine is 12 years old I would suggest doing a high temperature wash with a cleaner as pressure system maybe partial blocked
    #490432
    Posi
    kaibart wrote:Given that machine is 12 years old I would suggest doing a high temperature wash with a cleaner as pressure system maybe partial blocked
    Thank you.
    I will try that.
