out of balance during wash but spinning fine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum out of balance during wash but spinning fine
  • #69488
    lushy0709
    Hi all
    beko wma 641w
    This machine washes and spins fine when empty, spins fine with either light or heavy load, but when on wash cycle with any type of load it bangs and jumps about enough to pull the motors electrical plug off :eeek: . I’ve checked the weights springs and shocks and all seem fine. Any help greatly appreciated.
    Thanks Ian
    #374962
    Check the motor’s tacho generator connections.
    #374963
    Re: out of balance during wash but spinning fine
    And the tacho magnet itself, quite prone to disintegrating on BEKO motors.
    #374964
    lushy0709
    Hi thanks for replying I’ve checked the connections they are ok used multimeter. if I connect multimeter to wires of tacho and manually spin drum around should I see some voltage? magnet is in one piece no visible signs of damage.
    #374965
    lushy0709 wrote:if I connect multimeter to wires of tacho and manually spin drum around should I see some voltage?
    Yes!
