Stoves Newhome Range model 1100DFaDL. The fan oven does not switch off fully, it is always warm inside, i.e. cool enough to touch & does not get hot, seems to stay at same temperature. Only way to switch it off is to cut the main power at the wall switch.
sure am – in the last two weeks, the freezer seal has gone, the washing machine started playing up and the oven is on the blink! – must be some appliance law of the universe in action! 🙂
Your expertise is appreciated. I’ll check the earth connections but it is strange as the range is just over two years old and has not been moved since it was installed. I’ll let you know
cheers,
Kevin
