oven cabinet fan
  • #94705
    les65
    hello all, we have a Belling built in double oven, the problem is that the cabinet cooling fan will hardly run although it attempts to. I’ve renewed the fan thinking it was an easy fix, but its still the same. after looking on the internet it appears there is a PCB board that also controls the fan. If this board was faulty would it cause the fan to hardly run? is there any means to test this or is it a case of replacing and hope it works. Everything else works fine just the fan attempting to run but it just can’t!
    Many thanks les.
    #458060
    kaibart
    Re: oven cabinet fan
    Is this a gas double oven? A model number would be helpful
    #458061
    although a model would be helpful a lot of belling fans are controlled by a board and yes when they go faulty the fan wont run properly
    les65
    Thanks for the replies, it’s a built in belling double electric oven, the fan giving problems is the cabinet cooling fan, not the oven fan. Everything works ok on the oven just the cabinet fan struggles to run. I’m just trying to confirm the fan PCB board could cause this problem before I order a new one?
    #458063
    les65
    It’s a double built in electric oven, everything works fine except the cabinet cooling fan.
    #458064
    les65
    Thanks for the reply Dave, it sounds like it could be the fan PCB board then, the fan itself is new so I’ll get a board and hopefully it’ll sort it.
