oven cutting out
  • #93531
    alan60
    hello, i have a diplomat oven adp3322/3340 s/number05206520 that after appox 30mins of pre-heating & cooking all power to the over cuts out.
    i have fitted a new main thermostat & new safety thermostat but still cutting out.
    please advise as what i may need to now look at, or replace.
    also if i turn the power back on the oven will work but will cut out again.
    thank you
    Alan
    #454695
    Re: oven cutting out
    the unit may have a cooling fan that blows cold air in the control panel. if this fan is not working then it will cut out
    alan60
    hello Dave,
    thanks for your advice, will look into buying a new cooling fan
    Alan
    #454697
    may not be the fan as there is a thermostat that controls it that may be the fault
    find the fan unit (if fitted) and see if it has jammed. you may be able to lubricate it as a short term test
    https://shop.ukwhitegoods.co.uk/1259006 … -fan-motor
    fitted to model A3340
    you need to get the correct model before ordering off the oven
    alan60
    Dave,
    thanks for info
    will do as you suggested
    Alan
