Oven dead after power cut
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven dead after power cut
  • #81758
    Bee1
    I’m new here and I hope somebody can give me some advice.
    I have a Leisure LEVC67W, it has a digital clock; I’ve had it for appr. 2.5 years (needless to say, it’s out of warranty).
    Since last Christmas, every time when there’s been a power failure, the oven is dead, no light, no fan, no heat. I know about resetting the clock, so that’s not it. All the other functions of the cooker are not affected. And the funny thing is, when I keep turning the oven knob now and then to try, at some point the oven springs suddenly back to life again. This usually happens after a few hours up to a few days. Then the oven is again fully functional and works each time I switch it on without fail – until the next power cut, that is.
    At the moment the oven is again not working, and we’re having little power glitches daily, so there’s not much chance.
    Am I right that there’s something wrong with the timer, some wobbly connection perhaps? Is there something I can do easily myself about it? If not, can anyone tell me how much the repair by an engineer could cost me? (I live in Cumbria.)
    Thanks in advance for any constructive replies.
    #417597
    philfish
    Re: Oven dead after power cut
    It does sound like it could be a timer fault, but, just as an off chance pull the knob of and have a look see if the knob is not worn and slipping round on the selector switch shaft. Might even be the switch but without seeing it etc I can’t really tell.
    I don’t know how much a local engineer to you would cost and unfortunately I’m not local but you can search for a local engineer on here.
    Phil
    #417598
    Bee1
    Hi Phil,
    Thanks for your reply. I’ve had a look, but the knob seems to be alright, at least to my technically inexperienced eyes. And if the knob was worn, why would the fault only happen after a power out?
    #417599
    philfish
    I was just hoping it was coincidence and a simple repair for you to do yourself. As I say it was an off chance, so if everything else seems ok I would be looking towards the timer.
    Phil
