Oven died after power cut
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven died after power cut
  • #72926
    wenger
    Morning all!
    Have a Baumatic (I think) 180.
    Had a power outage and since then oven has not worked. Clock at top works fine though. The cooker is hard wired into a cooker socket (red switch type) with a 13 amp socket as part of it – this socket works fine.
    Is there a fuse in the socket, or could it be a fuse in the oven? Have read elsewhere that the element may have blown, but when that went a few years ago, I am pretty sure the fans were still working (just blowing out cold), but now the fans are not working either.
    Any ideas?
    Sharon
    #385974
    Re: Oven died after power cut
    If the oven timer is working then it’s almost certainly on automatic, which wil kill the power to the oven.
    Generic instructions are here: http://www.ukwhitegoods.co.uk/help/fix- … -dead.html
    wenger
    K,
    😀 😀 😀 THANK YOU SO MUCH!!! That did it. Never used that feature before :rolls: .
    So much appreciated, thought I was in for a bill for at least an element replacement.
    Thanks again.
    Sharon
