Oven door.
  • #17306
    stasher
    I’m trying to remove the door from a Creda under bench electric oven Model E010EW, I’ve turned the small discs in front of the hinge arm- tried pushing, pulling and lifting, no good.
    What’s the right way to free the door?
    Any help please?
    #173731
    Re: Oven door.
    Once you have locked the top arm you should be able to lift the bottom arm on each side a little, then lift the door slightly and press down on the lower arm, I have just experimented on my Creda oven door and it is a fiddle but I removed it in 20 seconds. There is a large notch on the top edge of the lower arm and a much smaller one on the bottom edge, both of which slot into place. Perseverence is what is required.
