OVEN DOOR
  • #93924
    Eastcombe
    I have found a chip on my glass oven door. The side that faces the oven. Should I try to repair it or just leave it?
    #455923
    Re: OVEN DOOR
    you can repair it. you see all the adverts on tele about repairing windscreens. to do this they use a plastic filler. in your case it wont work because of the heat
    if you leave it 2 thing could happen
    1 nothing as long as the door still seals
    2 the glass will shatter. its toughened glass like car side windows so it breaks into lots and lots of little pieces
