Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Oven door fault [Belling 478GR]
- This topic has 8 replies, 3 voices, and was last updated 20 years, 8 months ago by
spiderman.
August 17, 2005 at 7:19 pm #11385
spiderman
ParticipantThe outer glass panel on the door catches on the oven body when opening the door. This only happens on the left-hand side and appears to be caused by a faulty hinge. Is it possible to buy replacement hinges and how easy is it to fit them?
August 17, 2005 at 9:08 pm #145172Penguin45
ParticipantRe: Oven door fault [Belling 478GR]
Top oven hinges are p/no BA6100995.
Main oven hinges are p/no BA6100996.Worth checking for fit if the hinges before ordering – there is a link at the top of this forum which is worth checking out first.
An email to spares@ukwhitegoods.co.uk if you wish to order.
Penguin45.August 17, 2005 at 9:13 pm #145173Dave_Conway
It sounds like the hinges and possibly the hinge supports also, both doors take the same hinge:
It’s actaully manufactured by Creda so I’ll quote those prices as they are less than half the Belling price 😉
Door hinge part number 6100995 £9.95 each
Door hinge supports part number 6100996 £3.95 eachAll inc VAT, please add £3.95 postage.
An email to spares@ukwhitegoods.co.uk please if required 🙂
Pretty straightforward to be honest, refer to the user manual on how to remove the oven door for cleaning, if you don’t have that, see the “sticky” at the top of this forum on removing oven doors.
August 17, 2005 at 9:14 pm #145174Penguin45
:wave:
August 17, 2005 at 9:14 pm #145175Dave_Conway
:wave:
August 18, 2005 at 10:27 am #145176spiderman
Thanks for super fast response! Just a bit confused though. You mention hinges and hinge supports but what I’ve got in my hand (having successfully removed the main oven door) is just a single, integrated contraption, marked Nuova Star B, which has a spring connected to a support arm and a hinge at the bottom. Is this a hinge or a hinge support?
August 18, 2005 at 10:59 am #145177Dave_Conway
The hinge by the sound of it.
The hinge supports are on the oven itself (the part the hinge locates when fitting the door back on).
August 18, 2005 at 6:52 pm #145178spiderman
Well I’m ready to place my order but I’m still confused. Dave_Conway quoted parted number 6100996 as being a door hinge support whereas penguin45 quotes that number as being a door hinge for the main oven. I do require a door hinge for the main oven. Can you confirm the part number. Also are these things best replaced as a pair even though only one is defective?
August 18, 2005 at 9:38 pm #145179Dave_Conway
Ooops 😳
Sorry about that.
Main oven door hinges are 6100996, my mistake.
I don’t think you need the hinge supports, and yes, a pair is normally the best bet as one damaged one can lead to weakness of the other.
