Oven Door for Diplomat Select 620 (AHY3601)
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven Door for Diplomat Select 620 (AHY3601)
  • #18403
    dave111
    The glue keeping glass oven door affixed to the metal frame has come away and the glass is only held in place across the top.
    The oven is still usable but awkward.
    The inner glass is fine.
    How is the best way to deal with this problem.
    Is there a suitable glue that is recommended?
    Or is a new door the best way to go.
    All advice much appreciated.
    #178901
    Re: Oven Door for Diplomat Select 620 (AHY3601)
    This is what you want:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=302
    It will stick anything to everything, for ever.
    Dismantle door, clean off all trace of the old glue, get it all spotlessly clean, rebond and weigh down for 24 hours with Encyclopedia Brittanica (the paper version, not the CD).
    dave111
    Is this the same product – looks similar….
    http://www.maplin.co.uk/Module.aspx?ModuleNo=29013
    thanks.
    #178903
    dave111
    can anyone confirm if this is the same product available at maplin.
    thank you.
