Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › oven doors tnat will not quite close tightly
- This topic has 9 replies, 5 voices, and was last updated 10 years, 1 month ago by
melec.
February 8, 2016 at 9:29 pm #87543
melec
ParticipantAm I the only one that struggles to resolve this problem ?
I am talking about when the door leaves about a 5mm gap on closing obviously allowing heat to escape and damage control knobs etc
One thing I learned long ago is that it is never the hinges nor hinge receivers
On some models I had success with ‘reforming’ the front of the oven so hinge receivers sit back more but one or two came back months later with same fault
I always tell people that they must have put excess weight on door when fully open and down stressing the frame of oven which cannot be easily rectified if metal stretched.
I have his fault regularly on various models single and double ovens
Am I missing something ?Is this a common thing and is there a trick or repair kit plsFebruary 8, 2016 at 9:49 pm #435204electrofix
ModeratorRe: oven doors tnat will not quite close tightly
have had various things
sometimes hinge, sometimes receiver and had a creda where the front of the cooker had bent
February 8, 2016 at 10:44 pm #435205melec
ParticipantRe: oven doors tnat will not quite close tightly
I have never fixed one with a hinge or receiver !!
My rule for ordering hinges is only do it for a sheared one that is obviously faulty
Just my experience ( costly sometimes , I have quite a few new Hinges in stock that I ordered mistakenly that they will probably bury with me !!!)February 9, 2016 at 8:43 am #435206electrofix
had a Neff last week where the receiver is at fault
also had a Zanussi with receiver fault but managed to take them outside and straighten them with a hammer on the flag stones
February 9, 2016 at 1:03 pm #435207melec
you deserved your money on that one Dave !!
Does n,t sound like you boys get too many of these oven door issues
I get them regular but mostly old ones where people are in a mind not to have the work done anyway
Most common makes I do are Fagor Aspes and Edesa which are from the same factory as I am sure you know . ( Now an embargoed Factory on and off )
I doubt you see many of them ??February 9, 2016 at 8:57 pm #435208melec
Got one tomorrow as it happens (Aspes)
Always same comment from customer that they need a new door seal because door won’t close and losing heatMarch 4, 2016 at 5:37 pm #435209pmb
We replaced hinge on a Bosch oven twice, 2nd time under
Gaurantee, both times it solved the problem, not closing fully
But looking at hinge I cannot see what’s causing problemMarch 4, 2016 at 6:22 pm #435210Martin
pmb wrote:But looking at hinge I cannot see what’s causing problem
In that case the hinge receiver/socket also needs replacing.
March 5, 2016 at 5:34 pm #435211eastlmark
pmb wrote:We replaced hinge on a Bosch oven twice, 2nd time under
But looking at hinge I cannot see what’s causing problemIts a worn “heel” on the hinge bracket that the spring loaded roller runs over (Between the bottom of the door and the hook you lift to release the door). It gets rounded off instead of being almost a point. Almost all the Bosch/ Neff and Smeg ones never need sockets. They are being made of increasingly softer metal though..
March 6, 2016 at 7:35 pm #435212melec
Seems like this IS a fairly common occurance giving the same consistent symptoms that 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time there is nothing visible or obvious
Definately though different solutions depending on the manufacturer
I am still going to use my hammer and steel punch to just force back the receiver a tadge as a first response ( just hit the visible part of the receiver through the hinge aperature twice but firmly then put door back on and see if closes )
I must admit to noticing concerned clients expessions when I am hitting their oven with a hammer but my success rate is high -
