Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Oven fan continually running
- This topic has 9 replies, 4 voices, and was last updated 9 years, 10 months ago by
mikesmeg.
June 7, 2016 at 1:02 pm #88492
mikesmeg
ParticipantI have a SMEG dual fuel cooker (SUK81MFX5) and since yesterday the oven fan has been running continuously.
Its not the cooling fan because that cuts in and out as it should and is much noisier.
The only way to turn it off is to put the oven in Auto.
I have a feeling its a faulty oven selector switch.
Any other ideas before I start dismantling?Mike
June 7, 2016 at 1:07 pm #438327kwatt
KeymasterRe: Oven fan continually running
I suspect that you will be correct and it’ll be the switch, the only other thing to check first is the fan initiation thermostat which, if locked on would do the same I think.
The switch is this one:
http://shop.ukwhitegoods.co.uk/81173022 … tor-switch
The thermostat one of these two:
http://shop.ukwhitegoods.co.uk/81873103 … thermostat
http://shop.ukwhitegoods.co.uk/81873118 … thermostat
June 7, 2016 at 1:11 pm #438328mikesmeg
ParticipantRe: Oven fan continually running
Thank you for such a fast response.
Why would the oven fan have a thermostat, isn’t it either on or off depending on the chosen oven function?Mike
June 7, 2016 at 1:16 pm #438329kwatt
The small thermostats there control the cooling fan, switching it on or off as required.
You can get the general gist of how they operate from the following:
http://www.ukwhitegoods.co.uk/help/spar … hermostats
http://www.ukwhitegoods.co.uk/help/spar … fan-motors
June 7, 2016 at 1:21 pm #438330mikesmeg
So if the cooling fan is working ok, and its the separate oven fan (the one for air circulation) that’s faulty, it wont be a thermostat.
Any other ideas for the air circulation fan?
June 7, 2016 at 1:27 pm #438331kwatt
Correct.
You have two fan motors, the cooling fan and the oven fan motor.
Cooling fan cools the space around the cavity, oven fan motor circulates the air within the cavity.
The oven fan motor should run continually whilst in a fan oven or fan grilling mode.
June 7, 2016 at 1:30 pm #438332mikesmeg
So the problem is that the oven fan motor is running continuously, in any mode or when the oven is off. Only putting the oven in Auto stops it.
So, Selector Switch ??? any other possibilities?
June 7, 2016 at 1:32 pm #438333kwatt
if it’s the oven fan motor the selector switch would be the first thing to look at, 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance that it’s arced and got a constant live.
January 10, 2018 at 1:47 pm #438334Freemanville
On my AEG oven – the cooling fan is continuously running, can only switch it off by turning mains off – could it be as simple as replacing the ZN limitor which is ‘in line’ to the cooling fan?
January 10, 2018 at 2:20 pm #438335electrofix
ModeratorRe: Oven fan continually running
would need model and pnc of the unit to look it up and find out which unit you are talking about
