Oven glass door adhesive.
  • #9653
    ChrisR
    Hi gents 😀 .
    Does anybody know what adhesive manufacturers use to fix the metal brackets to the glass doors on ovens?.
    I`ve got an old Credaplan single oven with the model number missing that needs either a new door or the existing one `reglued`.
    I`ve got a feeling this thread may have been mentioned before but I can`t find it.
    Thanks. Chris.
    #135080
    Dave_Conway
    Re: Oven glass door adhesive.
    Servisol (Ambersil) Chris is what we use and sell via the shop here 😀
    Connect’s part number is sersil1
    #135081
    dpm
    Don’t you find silicone a bit soft for that application?
    #135082
    Lawrence
    I used this on a friends electrolux oven to re fit the brackets onto the door glass and it worked a treat it temperature range is suitable for ovens
    Lawrence
    #135083
    SWERV
    😆 I’m just re sealing an oven door at the moment. The sealant I use is from kitchen economy(part no.WA1005).I’ve been using this for a while and it works great!.
    #135084
    Hi Chris,
    the old Credaplan ovens used to hide the model ident along the lower edge of the bottom trim. The only way to see it was to get your eyes lower than the trim and look up, bang in the middle. All ovens began with 48XXX and three other digits. Just in case you need to go back at all…
    Kevin
    #135085
    roly16
    That sersil1 sealant is only rated up to 230degrees. The one I use is Ambersil 1008A Engineering Adhesive Sealant which is rated to 300degrees and I’ve never had one fail. I get it from a local Qualtex supplier but I don’t know if it’s a Qualtex part. I can find out if anyone’s interested. It’s expensive at about £10 for a 75ml tube.
    Geoff
    #135086
    ChrisR
    Thanks lads for your replies 😀 .
    #135087
    roly16 wrote:That sersil1 sealant is only rated up to 230degrees. The one I use is Ambersil 1008A Engineering Adhesive Sealant which is rated to 300degrees and I’ve never had one fail. I get it from a local Qualtex supplier but I don’t know if it’s a Qualtex part. I can find out if anyone’s interested. It’s expensive at about £10 for a 75ml tube.
    Geoff
    Qualtex part No: is MIS12 for 75 ml and MIS120 for 300 ml tube.
    #135088
    roly16
    Thanks for that information iadom
