Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Oven got no heat!!
- This topic has 14 replies, 3 voices, and was last updated 18 years, 10 months ago by
stretch79.
May 29, 2007 at 8:33 pm #27729
stretch79
Participanthi all hope someone can help me, i have an electrolux fan assisted oven, part number EOB970X1, a while ago it went bang and tripped out the MCB in the mains board now after reading similar i ordered and have fitted a new element in the cooker, now im a bit gutted and confused as the light, grill work but no heat for the fan oven?? have seen somewhere that it maybe a stat or something but im no appliance engineer
any help appreicated greatly
cheers
rob
May 29, 2007 at 8:36 pm #215363Penguin45
ParticipantRe: Oven got no heat!!
Is the oven fan running, or is the oven completely dead?
May 29, 2007 at 8:38 pm #215364stretch79
Participanti can hear the fan running ie noisey but no heat have it on now after fitting element gets a little warmer than before but not high enough 50 degrees if im lucky
cheers penguin
May 29, 2007 at 8:57 pm #215365Penguin45
EOB976X1?
There is a single shot thermal cutout on the back of the oven – this would give you no heat at all. Otherwise, it has to be the control thermostat.
Thermostat is 3051770-01/8
Cutout is 3192609-04/2spares@ukwhitegoods.co.uk will be able to supply for you.
Penguin45.May 29, 2007 at 9:14 pm #215366stretch79
Participantblimey you knew the number of the cooker! lol yeah sorry as you put it EOB976X1, thats th one.
so im after the cutout then before the stat then penguin??but it does give a little heat under 50 degrees so prob still cutout penguin?
appreciate the help!!
May 29, 2007 at 9:26 pm #215367Penguin45
So long as you are sure that you are getting some heat, it will be the main thermostat (the one on the control panel) that’s at fault.
May 29, 2007 at 9:28 pm #215368stretch79
Participantok brilliant really appreciate the help penguin i will try and order the part and get it fitted asap need my food lol
and that’ll fit my EOB976X1?
May 29, 2007 at 11:49 pm #215369Penguin45
It certanly does, Stanley.
:p45:
May 30, 2007 at 5:18 pm #215370stretch79
Participantmany thanks stanley your a gent!!
July 4, 2007 at 5:22 pm #215371stretch79
Participanthi again tried the two items, the element and the thermostat and no luck so will the thermal cutout work for sure??
cheers
July 4, 2007 at 8:19 pm #215372Penguin45
Rob, with respect, have you actually tested any of the components?
All that’s left is the safety cut-out………
July 5, 2007 at 4:34 pm #215373stretch79
Participantwell yes turned on etc penguin still nothing so will try this now and see what happens otherwise im baffled..
August 1, 2007 at 2:36 pm #215374stretch79
hi all again just a quick one and only just realised this so yes im simple lol
now i may of replaced the wrong element i replaced the grill element but not the element that sits behind the fan inside of the oven, and going by my problems you reckon i should change this before as im thinking this may be the problem i have??
that is my last question so help greatly wanted many many thanks all
rob
August 1, 2007 at 3:10 pm #215375smartin
if this oven is a multifunction oven and you are selecting a cooking symbal that looks like this = then it has 2 elements one buried under the bottom of the machine and an element that surrounds the grill element above that would explain half heat if bottom element has failed, if you are selecting a symbal like a circle with a fan inside it then it only uses the element around the fan hope this helps smartin
August 1, 2007 at 3:32 pm #215376stretch79
hi there the symbol is a square (circle same thing i know) with a fan in the middle so im presuming that the oven is heated by this element then the fan push’s out the heat to oven cook food?
so thats the element i may need now??
cheers smartin
