Oven indicator light always on
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven indicator light always on
  • #93845
    Western57
    Hi I have a beko bcd545aw cooker. When simply powered, the oven indicator light is already glowing red.
    Once I set the time and turn the oven temperature knob to turn oven on, it trips the electrics.
    The oven is 2013 but never been used.
    Does anyone know what the issue might be?
    #455724
    Re: Oven indicator light always on
    damp if its not been used since 2013
    to be able to dry it out you need to get it hot and you cant do this because it trips
    cant find this model are you sure its correct also look for a 10 digit number starting 7*****
    you may have to remove the elements and put them in a friends oven for a few hours at 200 to dry them out. It may be just one element causing the problem but you would need to check them with an insulation tester
