Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Oven just doesn’t get hot enough
- This topic has 2 replies, 2 voices, and was last updated 15 years, 7 months ago by
misterfink.
September 20, 2010 at 2:09 pm #57357
misterfink
ParticipantIm curious as I have an odd problem (that I detailed in another post) and now I think the oven fan may be turning too slowly. Im just wondering if it’s having anything to do with my oven not getting hot enough.
cheers
September 20, 2010 at 3:55 pm #330931Martin
ParticipantRe: What effect would oven fan turning slower than normal ha
misterfink wrote:Im curious as I have an odd problem (that I detailed in another post) and now I think the oven fan may be turning too slowly. Im just wondering if it’s having anything to do with my oven not getting hot enough.
What a pity you didn’t add your question to your original post then we can all get the full picture. Nevertherless HERE is that post. Keeps it nice and tidy that way.:wink:
In answer to your question though, oven fans turn very quickly indeed (bit like a cooling desk fan set on full whack you might say). So the instant the fan oven turns on and you open the door the blast of hot air in your face should all too apparent. Fan motors suffer bearing wear over years of use and as a result can slow up to some degree. So if it isn’t going at full whack with loads air hitting you in the face it may need a new fan motor. If it is running full whack but no heat apparent, then the element is at fault. The latter being a more common failure.
HTH?:D
September 22, 2010 at 12:54 pm #330932misterfink
Tricity Bendix – SE454W
Hi there.
Well I can tell you that a new thermostat was fitted by an engineer (was going to do myself but had trouble working out how to access the thermostat itself).
Once that was done, I set the temp to 200c and used an oven thermometer to check the temp. Even after pre-heating for 30mins, the thermometer only showed 160c. This is when I began looking at the fan being the cause of the issue, so I just bought and fitted the new fan. The fan does visibly appear to be turning quicker than the old one, and it sounds a tad noisier. But after checking the temp again, the same thing seems to be happening. I thought maybe it’s just a crap oven thermometer, but find it hard to believe that it would be out by around -40c.
one thing to note is that since the problem began, the ‘Main Oven’ light has never really stayed on that long once I set a temperature and wait for it to register on the thermometer. I googled around and it seems that on most ovens, the light only goes off once the desired temperature is reached. I didnt think about this much, and just thought that perhaps the oven doesnt keep the elements for long perdiods, and will simply keep cycling at fixed intervals until the temp is reached, and then it will cycle only when the thermostat thinks the temp is too hot/too low.
I’ve now spent £140 trying to fix this problem, and Im now at a loss.
I intially thought about the element being faulty, but 1) it does work 2) I checked if for visible cracking/damage when this problem first occurred and I cant see anything that looks bad.
