Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Oven keeps tripping the RCD
- This topic has 7 replies, 3 voices, and was last updated 10 years, 7 months ago by
shuggy81uk.
August 18, 2015 at 11:57 am #85857
shuggy81uk
ParticipantHi Guys,
I have a 10 year old + Siemens single oven (hb24054gb). The other day it tripped the RCD and seems like its the oven. When the temp is set to 0’c then oven/grill switches on fine, however when you try to change the temp then it trips the fuse.
I am seeking advise if you think it’s the temp regulator that’s causing the issue here ?
S
August 18, 2015 at 12:35 pm #429672Andy jones
ParticipantRe: Oven keeps tripping the RCD
Will be an element fault by the look of it. Will need to be meggered to know for sure which one is causing it
August 19, 2015 at 11:06 am #429673shuggy81uk
Thanks for the help Andy.
Am I right in guessing there will be 2 elements in the oven, 1 x grill and 1 x oven ?
August 19, 2015 at 12:08 pm #429674Martin
shuggy81uk wrote:Am I right in guessing there will be 2 elements in the oven, 1 x grill and 1 x oven ?
Correct! And likely as not the fan oven element (behind the removable the back wall lining) will be at fault.
August 19, 2015 at 12:17 pm #429675Andy jones
As Martin said likely to be fan element but would have to be tested to be sure
August 20, 2015 at 3:07 pm #429676shuggy81uk
Do you know how one would go about testing the element ? Is it just testing using an ohm meter ?
August 20, 2015 at 3:26 pm #429677Martin
shuggy81uk wrote:Do you know how one would go about testing the element ? Is it just testing using an ohm meter ?
We have to assume those asking for help have a reasonable knowledge of electrics. Your safety is all important and asking such fundamental information does give cause for concern. My colleague referred to using a Megger (Earth insulation tester) as the correct way to diagnose faults with elements etc. And if that’s what you refer to an an “ohm meter” then the answer is yes a Megger is a Megohm meter.
Stay safe. 😀
August 20, 2015 at 3:28 pm #429678Andy jones
No. It needs to be tested using an insulation tester ( megger )
