Bosch double oven built under HBN43B250B / FD9001000010
Bottom oven light bulb keeps blowing, replaced two bulbs so far.
I searched on the internet and one post on there said it’s the
bulb holder needs replacing?
I pulled the oven out and it looks like you have remove the
complete side panel to access the bulb holder.
is that correct and is it a easy job.
or is it a job for a technician
Eveready 25w oven bulb that’s what I used, should I try. A Bosch one.
Model no HBN43B250B/01
am I right about the side panel has to be removed to replace the
bulb holder, after sliding the cooker out from under the work top.
if you look at the lamp it clips into the unit. it is possible to bend each of the clips so the lamp will come out then swop the wires and clip the new one in without removing the panels
you need to make sure that when its back in place that the wires cant touch anything
