Oven not getting to correct temperature Electrolux EOB 976
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven not getting to correct temperature Electrolux EOB 976
  • #59310
    david kinsey
    I have a Electrolux EOB 976 oven which is not getting to temperature, and im not sure if I should replace the element or the thermostat? the problem seems to have started after I turned on the grill instead of the oven and left the door shut which caused the oven to get really hot.
    any advise would be a real help
    thanks
    David
    #337653
    cornflakes
    Re: Oven not getting to correct temperature Electrolux EOB 9
    could be thermal cut out blown
    does your oven heat uo at all
