Oven not working – NEFF
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven not working – NEFF
  • #33205
    Pete12121212
    I just went to put a pizza in the oven haviung left it to pre-heat and the oven was cold with the temp light still on and the fan going. I have checked and the grill still works.
    The oven is Neff – ENr B1820N0GB/03 FD7903 B-AP22-7.
    Seems like the fan element needs replacing but could it be anything else?
    Thanks Pete 😡
    #237793
    gegsy
    Re: Oven not working – NEFF
    Nah, circoctherm element p/no 499003 available from spares@ukwhitegoods.co.uk
    Pete12121212
    Hi, thanks for the speedy dispatch of my order over xmas – arrived today.
    2 questions relating to the fan element:
    1. On the element I have removed it states 2400W, where as the new one is 2300W. Is this ok, and would a genuine Neff part be 2400W?
    2. How do I connect the earth wire from the oven to the element as there is no connector on the new element.
    Your help is appreciated.
    #237795
    gegsy
    New style does away with earth tag on element. You will need to isolate safely the earth wire making sure that whatever you use to isolate, is electrically insulated,made of heat resistent materiel and won’t be able to dangle onto the circotherm fans moving parts.
    As for the power rating, Im sure that will make no difference to its performance IMHO.
    As always power off before attempting :plug:
    Pete12121212
    So for example wrap the earth connector in a heat resistant tape of some sort?
    tks
    #237797
    gegsy
    Or crimp a ferrule onto the end and tyrap it away 😉
