Oven ordered this should fit?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven ordered this should fit?
  • #89113
    ShaneWilloughby
    Ordered a new oven and gone a basic like for like as we plan to move in the next 2-3 years. just want to make sure that it should fit between our kitchen units like the previous one did?
    OLD OVEN:
    Howdens/Lamona Electric signle fan oven HJA 3300
    outer width – 560mm
    outer depth – 561mm
    outer height – 594mm
    Dimensions of installation settings
    Width 560mm
    Depth 540mm
    NEW OVEN:
    Hoover HOC709/6X
    Measurements:
    H59.5 x W59.5 x D55cm
    Just want to make sure that my new oven should easily fit where our old one is which is under a gas hob between kitchen units.
    Anyone have the hoover HOC709/6X? has good reviews on reevo and for £200 seems like a good basic oven buy.
    Help appreciated.
    #440359
    don
    Re: Oven ordered this should fit?
    hi Shane
    Yes the Hoover will fit.
    However please be aware of my previous post re your gas pipe here in your last thread on this oven.
    Don
    #440360
    ShaneWilloughby
    Thanks don! Yes I will look at this and hopefully the gas pipes will be fine! if not I know a plumber who could do this, just hoping as its very similar depth that it will not be needed to be moved. What are the chances pipes will have to be moved? its it 50:50 or just all depends on the positioning?
    #440361
    don
    50:50. You will know when you push the oven back. You get to the last couple of inches and it won’t go any further 😉
    Don
