Oven reaches temperature – put food in – temperature reduces
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven reaches temperature – put food in – temperature reduces
  • #41629
    Andrew50
    I have a NEFF double oven 4/5 yrs old – oven is warmed up, the food is put in and temperature drops about 40 degs and doesn’t get any higher – any ideas?
    #270784
    Re: Oven reaches temperature – put food in – temperature red
    Does the neon come back on when you turn the thermostat up ?What oven seting are you using,fan,conventional ?
    Bryan
    #270785
    And you posted your question in the refrigeration forum? 😕
    #270786
    Moved.
    Penguin45,
    Moderator.
    #270787
    Andrew50
    r600a wrote:Hi
    Bryan[/quote
    #270788
    Andrew50
    Neon indicator does not come on. I have a fan oven
    #270789
    Andrew50
    Ignore my last reply about oven, my response to Bryan should be neon light stays on and yes I have fan oven. also I know that temp is not reached as have checked it with oven thermometer
