Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › OVEN SHUTTING DOWN INTERMITTENTLY
- This topic has 13 replies, 10 voices, and was last updated 20 years, 2 months ago by
jmears.
February 8, 2006 at 12:14 pm #15482
jmears
ParticipantHi anyone who’s on line.
I have an Electrolux built-in oven model ‘EOB 5630W’.
It is approx 2 years old and has started cutting out intermittently.
It happens after about 20 – 30 minutes, on oven or grill and is getting worse each time we use it.
The fan, oven lamp and the temp LED goes off, but the power light stays on.
After approx 15 minutes, everytrhing starts up again and the cycle continues.Can anyone advise what this could be (Thermal cut-out?) and how I fix it?
Thanks in anticipation,
JohnFebruary 8, 2006 at 12:45 pm #163745Dave_Conway
ParticipantRe: OVEN SHUTTING DOWN INTERMITTENTLY
It’s nearly always the thermal cut out on the cooling fan housing that causes this, it’s this part here:
Link to spare part 8996619267611
A forum search for the part number 8996619267611 will also help 🙂
Power off if attempting yourself please or check the repairs@ link below for an engineer..
February 8, 2006 at 3:15 pm #163746jmears
Many thanks Dave, I had already stripped it down and found that part with a blackened band around the centre so assumed it might be that.
It’s awfully expensive for such a tiny part (£25) from the site you gave me!
I have actually ordered one from a local spares shop now and they quoted £22, so it seems they are very fair.I do appreciate your help though, thanks again.
JohnAugust 15, 2006 at 2:36 pm #163747lkehoe
Hi John,
I have the same problem with my oven. It is the same model and the same age as yours too! I would be grateful if you could let me know if yours is now working ok with the new part.
Many thanks,
LorraineAugust 15, 2006 at 3:05 pm #163748Martin
lkehoe wrote: I would be grateful if you could let me know if yours is now working ok with the new part.
As the postee requested all this info way back in February it is unlikely you will get a response. But I would think you would be barking up the right tree so to speak on the exact same symptoms. 😉
Go for it Lorraine 🙂
August 23, 2006 at 12:24 pm #163749lkehoe
Thanks for your help. I now have the new part. I would be gratful of any tips on fitting it!
Many thanks and regards,
LorraineAugust 23, 2006 at 12:37 pm #163750Dave_Conway
Dave_Conway wrote:A forum search for the part number 8996619267611 will help 🙂
http://www.ukwhitegoods.co.uk/modules.p … ile=search 😀
August 27, 2006 at 12:14 am #163751J0KER
âž¡ This component is in numerous AEG/Electorolux Ovens.
It is not a thermal cutout just a substanddard Thermostat which operates the cooling fan for the external surfaces. If you cant feel a draught in front of the oven the fan is not operating, then the thermal cut out shuts down the oven. Penguin 45 assures me this is very rare!!!
Check the forum it happens a lot. LeaveAEG/Electrolux on the shelf poor quality control. The stat seems to last about 18 months.August 27, 2006 at 10:57 am #163752gegsy
Hi Joker
Are you an engineer in need of Trade Access? as you are advising in the public forum.If you need access please contact “site admin”.
December 27, 2006 at 8:15 pm #163753lanman
Came across this thread while looking for a solution to my problem with an Electrolux EOB5630. Thanks to all who suplied what appears to be a solution.
However, I am concerned that all I would be doing is replacing one faulty part with another, only to find that the same problem will occur in another 12 months or so!
Can anyone reassure me that the suggested part is an improvement on the original?December 27, 2006 at 8:30 pm #163754Penguin45
The original part number has been superceded several times, which usually implies that the part haas been changed in some way – alternate supply, redesign or improvement are all possible.
I have no idea if it has actually been improved or not – I would say that I have not had to return to any of the appliances which I have fitted replacements to, which must be a good sign. 😀
December 28, 2006 at 11:59 am #163755lanman
Thanks for that Penguin45. I guess time will tell. Still, at least if it does occur again i’ll know what it is straight away.
April 19, 2007 at 6:25 pm #163756robertgo
Thanks for the information. Have found suspect part and it is blackened around the centre. Replacement part on order.
Thanks again,
RobertGo
September 4, 2007 at 8:54 pm #163757Chriswalder
I had the same problems as those earlier posters on my Electrolux EOB5630X oven and just thought I’d report that having ordered the part no. 8996619267611 from the spares area and having just fitted it the oven is all working normally again.Thanks for the advice previously posted its much appreciated.
