Hello,
I have an older White-Westinghouse oven whose ventilation fan stopped working recently leading to excassive heat in the area around the knobs. I dicovered the cause to be a burnt out “timer-thermostat”. It is made by Campini model TY60-T. It is not the same as the simple TY60, which simply a thermostat. This thing apparently keeps the fan on for some time even if the temperature does drop below the thermostat’s threshold (I believe that should be around 50C).
Does anyone know where I can get this part from or of any other similar devices?
