Hello,
My partner was using the oven and she reported than when it was at temperature for a while, the electricity tripped. It then tripped every time she turned it on. I found this to be the case on my return home. I thought I’d try and test each element in order to see if it was just one element causing the fault. I tried the grill, electricity tripped.
I turned it onto oven elements (no fan) and nothing happened. I let it get up to temperature a bit, all fine. Max temperature, still fine. Switched it to fan, fine. I then tried every mode and it is still fine! Has the fault fixed itself? Is it likely to reoccur? Should I get an expert to diagnose it?
Thanks,
