Oven wont get hotter than about 100c
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven wont get hotter than about 100c
  • #28816
    bodgit0_0
    I have a bosch hss252a cooker i bought in germany, after a short while the oven failed to achieve any great heat.
    There are two elements, one gets warm to hot and the other stays cold. i have had the cold element checked whilst in germany and it checks out OK, since returning to blighty i have not been able to chase the fault as the cooker is in storage.
    It returns next week and would like some advice on how to tackle the fault and an idea where i can get parts for it.
    Many thanks
    Lee
    #220201
    gegsy
    Re: Oven wont get hotter than about 100c
    Sounds like a selector fault ie damaged contacts.
    Best thing to do is inspect selector contacts (power off of course) and see if there is anything obvious.
    Also you could check wiring from duff element back to selector using a multimeter for continuity.
    Interesting….. top and bottom elements, fan, but no fan element. I’d think that one of the elements has failed. Simple resistance test required. The appliance shows up on the BSH website, so spares will be available, spares@ukwhitegoods.co.uk will be able to supply for you.
    Do this before you wire it up…… 😀
    gegsy
    Thats what I thought initially Mr P,but……………
    bodgit0_0 wrote:have had the cold element checked whilst in germany and it checks out OK
    wsts
    gegsy wrote:Thats what I thought initially Mr P,but……………
    GregIs he on about the inner and outer top element though ? alot of people dont realize there is a base element in my experience.
    #220205
    gegsy
    Yes, I must stop assuming 🙂
    To clarify, grill element at top is a dual element and when appliance is switched to oven mode , half the element is activated along with the element under the floor of the oven cavity. Hope that clears that up. We await the OP’s reply 😀
    bodgit0_0
    Thanks for the replies, I will make an effort to get the offending item out of storage and try all ideas which should be in the next week. When you say the selector, are you reffering to the control knob?
    Any idea what kind of resistance I would expect when testing the elements, the reason I had the one tested was with the oven on it stayed stone cold?
    Will keep you posted on the outcome of the checks.
    Lee
    #220207
    gegsy
    Anywhere between 15 – 30 ohms would be normal.
    bodgit0_0
    Have at last checked the elements, the two that are underneath the oven compartment have the following readings, middle pins 7 ohms and the outer pins read 38 ohms.
    The grille element in the top of the oven is open cuirciut, and the control knob has good continueuity across the switches.
    How do i check the thermostate to see if it good or does it look like the top element could be the cause…
    Cheers in advance.
    Lee
    #220209
    SWERV
    If the top element is open circuit, I would say that is where your fault is.
    Merv
