Oven won’t turned on without turning on one of the left hob
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Oven won’t turned on without turning on one of the left hob
  • #91878
    mk1008
    What could possibly wrong it the oven won’t turned on without turning on one of the two left side hob ?
    This is also happening on the two right hob as well, they won’t turned on without turning on one of the two left side hob ?
    I got a secondhand electric cooker from fb marketplace.
    Gorenje E63175AW ( I think this model by looking at the image )
    Thanks in advance.
    #449598
    Re: Oven won’t turned on without turning on one of the left
    Someone’s been twiddling with the wiring :snig:
    #449599
    mk1008
    Thanks for the reply.
    I’m a bit unfortunate buying this from a not honest private seller 🙁 on fb market place.
    She didn’t admit that the cooker was a messed up.
    I only can used the left side of the hob.
    I opened up the hobs unit, there is a burned mark on the oven fibre glass insulation. Do you think it’s save to use the oven ?
    #449600
    mk1008 wrote:I opened up the hobs unit, there is a burned mark on the oven fibre glass insulation. Do you think it’s save to use the oven ?
    If it is brown in colour then very likely it is just staining from an adjacent vent that caused it. A blackened burn mark would indicate something electrical in the immediate vacinity fused at some point.
