Siemens WH54880GB/01 washer that has an intermittent problem in that the ‘End’ light sometimes comes on without it having spun. It pumps out fine, it spins and does everything you want it to 😕
BUT when it starts acting up, whenever you abort a wash (set dial to off) and then select any programme the ‘active’ light is on and away it goes 😯
You can turn it off, wait for the door to unlock, set any programme, seconds later the door locks and away it goes again without the need to press the start button 🙄
….first thought comes to mind here……..Module playing up!
Have any of you guys had the same fault?…Was it the Module??
I would appreciate your help if you know…thanks 🙂
