Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Overheating Candy GO F462-80
- This topic has 17 replies, 5 voices, and was last updated 13 years, 6 months ago by
2babecom.
September 26, 2012 at 6:42 pm #71687
2babecom
ParticipantHi I have a Candy GO F462-80 that is boiling on every wash even when selecting cold wash. It is crazy hot. I have replaced the Temperature sensor with no effect it is still boiling away.
Can you suggest what to try next?
Does this model have a thermostat as well as a temp sensor?Thank you
2babecomSeptember 26, 2012 at 7:32 pm #381932bryan-206
ParticipantRe: Overheating Candy GO F462-80
Can only be PCb then. Heater relay is most probably stuck on. Temp sensor feeds direct to PCb which in turn would switch off the heater. Did you use a cans thermister. There are two types both having different values.
September 26, 2012 at 7:38 pm #381933BobHope
i bet its the selector switch.
Bob.
September 26, 2012 at 8:22 pm #3819342babecom
HI Bryan-206 I dont know if I used a cans thermistor i found the part no for the temp sensor and ordered the same one. If it is the PCb will i need an engineer to change it I’ll have a go at most things but engineer i am not. Have checked out the part and it’s pretty pricy around £70 if I also need an engineer The costs starts to add up, there are some pretty good bargains in comet at the Mo.
Hi Bob. Selector switch? do you mean the knob where you choose the program, scuse my ignorance.2babecom
October 1, 2012 at 4:25 pm #381935bryan-206
PCb and selector switch are usually together on candy. Sorry previous post should hav read candy thermister. Vhfh
October 1, 2012 at 5:48 pm #381936helo_75
does no1 do any research?
take the knob off and spray the selector with switch cleaner
job doneOctober 3, 2012 at 7:55 pm #3819372babecom
Ok so i ordered a new pcb or circuit board and got the same part number.
it was called a Electronic control INVENSYS not program.
Now when i fitted it and plugged the machine back in all that happens is i get a flashing light and machine will not work.
I put the old one back in and it works but obviously still has the old problem.
So even though i ordered the same part number i was a bit dubious about the not programme bit, do you think this is why its not working with the new part.
They had one that was marked as programme but it was a diff part number to the old one.
So im £70 down and will probably now need to buy a new machine 😥October 3, 2012 at 8:24 pm #381938BobHope
what was the part number you ordered and what is the product code for your appliance.
Bob.
October 3, 2012 at 8:39 pm #3819392babecom
the part i bought from ransomspares.co.uk
it is part number RS154714 on their site
The part i took out of the machine has the candy part number 41027268 which when i checked it against the candy service manual it says its a 479t Electronic control INVENSYS not program
So i thought it would be ok as my machine is gof462-80
ClaireOctober 3, 2012 at 8:50 pm #381940iadom
ModeratorRe: Overheating Candy GO F462-80
2babecom wrote:
So im £70 down and will probably now need to buy a new machine 😥That would have gone a long way to paying for someone who actually knows what they are doing in the first place. :rolls:
October 3, 2012 at 9:08 pm #3819412babecom
comments like this dont really help fella
October 3, 2012 at 9:22 pm #381942iadom
But two highly experienced engineers have pointed you towards the selector switch, BobHope in his first post and helo_75 who just happens to work for Hoover/Candy. Have you thought of taking their advice, it would have been a much cheaper fix compared to a pcb that is the wrong part . 😉
October 3, 2012 at 9:34 pm #3819432babecom
bryan-206 wrote:PCb and selector switch are usually together on candy. Sorry previous post should hav read candy thermister. Vhfh
iadom see above post
if you have nothing helpful to say please get off this topic or ill report you to admin for trollingOctober 3, 2012 at 9:50 pm #381944iadom
So, did you try helo_75’s suggestion?
You could also have asked for help in identifying the correct part before you bought it.
I await the wrath of the forum admin. 8)
October 3, 2012 at 10:19 pm #3819452babecom
yes i sprayed the bloody switch which is attatched to the pcb circuit board.
The correct part was ordered actually as all the part numbers matched now if you have no help to give why dont you get off this thread and go annoy someone else!!!!!!!! -
