Overheating Candy GO F462-80
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Overheating Candy GO F462-80
Viewing 3 posts - 16 through 18 (of 18 total)
  • #381946
    BobHope
    Re: Overheating Candy GO F462-80
    Hi 2babecom,
    can i have the product code from the machines rating plate and i may be able to help.
    Bob.
    #381947
    helo_75
    2babecom wrote:yes i sprayed the bloody switch which is attatched to the pcb circuit board.
    The correct part was ordered actually as all the part numbers matched now if you have no help to give why dont you get off this thread and go annoy someone else!!!!!!!!
    ok, you asked, youll get your answer,
    the pcb you ordered is the right one, it just isnt programmed
    the spraying of the switch works rather well, i do it daily
    now you either pay for the right, programmed pcb, or you pay a hoover/candy engineer to programme the one you have
    the advice is here, you just didnt take it
    #381948
    2babecom
    ok i did take the advice actually i did spray the switch and no it didnt work!!!!!!
    i ordered the pcb board as someone suggested but no one told me about programmes etc so i just ordered the same part number.
    i sent the part back after talking to someone at Candy and got the right part and fitted it.
    Now the machine is working fine.
    Bearing in mind im not a machine service man, im just a lady asking for some advice i thought i may have been dealt with in a slightly better manner.
    Thanks bopehope for actually trying to help me its appreciated.
