P 08…AW23
  • #51395
    Just had a customer on the phone, she has an AW23 showing P08.
    According to fault codes.
    E08 Input voltage outside the range of 160-253V, 50/60Hz
    The E08 error code is displayed, washing cannot be started. After resetting, the error is indicated again if the cause is not rectified.
    Incorrect mains voltage
    Anyone else had this one, I’m stuck in due to the snow and now have a severe back log of calls.
    She is on her own and is unable to pull the machine out to access the plug, have advised her to leave it for 30 minutes and try again, any other suggestions other than a visit when conditions allow?
    Re: P 08…AW23
    Sorted,
    After two or three phone calls I managed to get her to clear the fault.
    I’m guessing there may have been either a dip or surge in the mains supply.
    Talked her through a reset and all now working fine. 😀
    Now if I could only work out a way to get paid for ‘home working’ then all this damned snow would not be a problem.
    Think I will go and build a snowman now. 8)
    timdowning
    Re: P 08…AW23
    Chris posted about this the other day. P08 means programme 8.
    Thats if I remember correctly.
