paddle fitting instructions lost
Home Forums Public Support Forums Help And Support Washing Machine Help Forum paddle fitting instructions lost
  • #36228
    Webby69
    Hi all, i recently purchased a pair of paddles for my hotpoint wf250 model and fitted the one that i needed, since then another has broke off and i seem too of lost the instructions on how to fit them.
    I know you slide them into place but cant remember what you do with the metal clip that is attatched to the drum that secures it in place.
    Ive lifted it up and slided it into place but its come off after one wash!!!!!
    Anybody done one before?
    #250122
    Re: paddle fitting instructions lost
    If you are trying to fit the latest Mk 3 type of drum lifter or even the earlier Mk2, make sure you are trying to fit it in the correct way round.
    The Mk 3 has three little notches on one end, this goes to the front, or look underneath, you will see a K shaped moulding at one end on either type, this also goes to the front.
    After you have lifted the tab inside the drum, position the six lugs into the holes and push back as hard as you can. If you do not hear a ‘click’ as the tab locks into place then the lifter will come out in no time at all.
    Webby69
    thanks for that works fine now
