Hi peeps
Any one had probs with these cutting out out after about 15 secs of cooking (micro and convection)? Everything just resets to initial power on display, i.e. the clock setting goes too.
Checked the thermistor seems ok (300k at room temp with temp variation reading ok), checked pcb earth (solder blobs aroung mounting screws), checked damper motor ok and weight sensor unit visibly checked.
Would appreciate any suggestions before replacing a very expensive pcb!
Cheers
Clive
