NNAS24MBBTQ combination M/W
I need to separate the door to get to the latch but can’t get it ti click apart and wonder if there is a knack or a place to start. I’ve never had a problem like this before so any help welcome.
Rob
You just need a small flat blade screw driver and prise the choke cover away from the top of the door. I normally start in the top corner by the hinge, the trick is getting the first part away, the you can use your fingers to gently pull at it, while using the screw driver.
Merv
Thanks Merv,
Brought it home and did it your way starting at the hinge and used a small filler knife and it came apart quite easily so thanks for the advice.
Rob
