Hello.
I’m looking for some info on this Panasonic american style fridge/freezer, please.
The machine i have been called to isn’t cooling the fridge adequately. There is ice visible through the grills on the coolling system (located at the bottom of the fridge), and I am presuming it then blows this cold air up through the back panel by means of a fan.
I can’t hear any fan whirring. I suspect it is either; open circuit, or jammed by ice build up.
How do I remove the ‘Cover coil’ (plastic cover on cooling system)?
Picture: https://connections.connect-distributio … r-b53v1-xb
I couldnt see any screws visible (although d empty/remove every shelf).
Thanks for any help.
