Panasonic = Gasket Warped After 2 Months + EcoNavi Setting
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Panasonic = Gasket Warped After 2 Months + EcoNavi Setting
  • #96011
    Findcount
    hi,
    hope Panasonic users here can help……..would i save more energy if i left the fridge + freezer on EcoNavi (Medium) temperature setting…………or put fridge + freezer on Minimum temperature setting ?
    also, after just 2 months……………the bottom corner of the freezer door’s gasket is warped……….allowing little cold air to escape – how can i fix this ?
    many many thanks for any useful info…………..
    #462061
    are you saying this unit is 2 months old from new
    if yes then any problems will be covered by the guarantee and it should not be up to you to fix it ( unless its down to misuse )
    Findcount
    electrofix wrote:are you saying this unit is 2 months old from new
    yes, under warranty……….but i reckon the gasket problem will resurface even after replacement………i wonder how the gasket could warp after just 2 months since gaskets should be the last thing to worry about !
    #462063
    then you may see a lot of the engineers
    but keep all the paperwork in case you have to make a point later
    but at the moment its not your problem as they have to pay for it
    Findcount
    electrofix wrote:then you may see a lot of the engineers
    could be my usual bad luck when it comes to buying things………….used to it by now
