Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Panasonic H43
- This topic has 8 replies, 5 voices, and was last updated 15 years, 6 months ago by
peeler40.
September 18, 2010 at 6:39 am #57318
peeler40
ParticipantHave a new Panasonic washing machine NA168VG2 in the workshop it
will do a quick wash ok but if you try to do a standard 40 degree wash
it stops after about 20 – 30 minutes and displays error code H43
Any ideas ? .September 18, 2010 at 9:07 am #330598electrofix
ModeratorRe: Panasonic H43
dont know fault code but first thought would be heater
programmer looking for a temp rise and not getting italso did google for panasonic fault H43 and got
http://www.digitalspy.co.uk/forums/show … ?t=1241675
hope this helps
September 18, 2010 at 10:22 am #330599peeler40
ParticipantRe: Panasonic H43
Thanks Dave ,The washing machine belongs to a fellow engineer and he has offerd me the mc for £40 i am thinking if i could not repair it i may get
my money back selling it for parts on ebay .September 19, 2010 at 5:18 pm #330600jess1ca
ParticipantHi Error H43 is …Water leak detector detecting water in the bottom plate/tray if you put machine on its back Carefully undo the screws in font of you or whip back cover off then get tired as there are a dozen or screws and dry out and then see where da water is coming from usually from da soap dish as her indoors is using too much soap Comet are selling da machine for approx £500 sooooo wot a bargain….
September 21, 2010 at 2:36 pm #330601peeler40
Hi Jess .Last time i looked at the machine the only thing i noticed was
a gate valve operated possibly by some sort of a stepper motot built into
sump .Very strange .I have seen a leak detecter on a bosch that machine had a solid base , but the Panasonic has a hole in the base like most washers.I will have a look and report back .Thanks for the reply.September 21, 2010 at 3:04 pm #330602bazza500
That hole in the base should be filled with a plastic plate and gasket. The switch which detects the leak is screwed to the rear of the machine at the centre and sits on the baseplate.
September 21, 2010 at 4:00 pm #330603jess1ca
ParticipantYeah yr right bazza There also a little sensor on the top of the pump housing…. its usually to much soap in dish causing leak, the dam thing only uses minimal water so you can be mean with the soap….
September 22, 2010 at 3:31 pm #330604expertcat
ParticipantI have found on these bottom of door seal comes unclipped and leaks from their
September 22, 2010 at 4:50 pm #330605peeler40
Thanks for all the replies , I am keeping the mc so i disabled the anti flood
device and the mc works fine .If it was a customers mc ,as their is no visable leak i think i would try raising the switch slightly say one or two
millie . -
