panasonic inverter
  • #43735
    loopey
    NN-A873S 1000W MICROWAVE Fitted new magnetron , will only run for about 30 secs then says , Refere to operating instructions before use ?
    now i have fitted loads of mags to the inverter systems but this one is
    doing my head in , could it be a faulty mag , never had a faulty one before. is there a reset i have to do ? any advice guys
    thanks inadvance phil
    #278331
    bzz67
    Re: panasonic inverter
    if you call paul at AWI, he has great knowlege on all these (01983 0817220)
    sounds like an inverter fault to me.
    #278332
    long shot
    from what you say the boards seems to be resetting had this happen on other microwaves when there is a crack in mag magnets and the leakage was affecting the electronics
    hope this helps
    loopey
    bzz67 wrote:if you call paul at AWI, he has great knowlege on all these (01983 0817220)
    yer paul was my 1st call , still wating for a call back , have fitted 3 mags to it now 1 from a repair that came in that i no that works and a new one from stock and a good s/hand 1 , all the same cuts out at 30 secs , this gets worse i fitted inverter board to it and its the same :bang:
    thanks phil
    #278334
    nice fault hope you find a solution before you pull all your hair out lol 😆
    #278335
    loopey
    Well i finaly cracked it a little over site again , it was the cam on the air flow flap had melted it was not energizing the micro switch ,
    http://img9.imageshack.us/img9/6209/02032009106.jpg
