Panasonic NA-140VX3 drum bearing replacement
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Panasonic NA-140VX3 drum bearing replacement
  • #91786
    jbenn155
    My machine is 5 1/2 years old and the bearings are noisy and some play can be detected when the drum is rocked up and down. I want to replace the drum bearings and seal. None of the spares web sites seem to be listing these items.can anyone tell me the bearing numbers so that I can buy them at a bearing stockist. Same applies to the seal in frontm of the bearings.
    thanks
    #449288
    don
    Re: Panasonic NA-140VX3 drum bearing replacement
    You have a machine which has a sealed tub assembly, part number PANAXW12018CWUK a non viable repair in my opinion as the assembly is well over £350.
    Don
    #449289
    jbenn155
    My 140VX3 was bought in Feb. 2012. Took top cover off this morning to find the tub is two part with fully screwed joint. Stripped it down. Front bearing is 6207Z 17mm wide, 35mm bore & 72mm O/D. Rear bearing is 6305Z 17mm wide, 25mm bore & 62mm O/D. Have already bought tub seal. Will buy bearings tomorrow. Haven’t yet identified seal. Couldn’t read any markings on it.
    #449290
    StevenSpence
    Hi there,
    I have the same problem on a Panasonic NA-140VX4 which I imagine is virtually identical to your one.
    I am just curious as to how this panned out as I am thinking of doing the same with mine?
    Did it all work out fine?
    Many thanks
    Steven
