panasonic na147vb2
  • #94541
    1totalshambles
    Hi. Getting fault code H41 flash up and machine gone up the creek.
    Looks as though via fault codes that this points possibly to the 3d sensor little pcb. On further investigation this little pcb has something to do with motor speed detection. So am I right in thinking it is Panasonics version of a Hall sensor that is fitted to Lg`s direct drive?? Any explanation welcomed please because I`m not sure.
    #457622
    Re: panasonic na147vb2
    https://www.manualslib.com/manual/92431 … tml#manual
    try this might help
    1totalshambles
    Damn decent of you Dave.
    Went there and it is the 3d thing that has 2 broken white wires. Ordered new 3d pcb because do not know where each broken white wires go to other broken white wires so therefore there`s a 50/50 chance of getting it wrong with the wires x`d and maybe nuking 250 / 300 quid main pcb was my worry. So me thinks play it safe!
    #457624
    1totalshambles
    UPDATE.
    Yes, replacing the 3d pcb has cured the problem. For those that do not know where this part is on the machine it is the small squarish plastic bit with the pcb underneath it top of the tank towards the front held on with 2 screws. Ya cannot miss it!!
