The door seal has come off the drum on this washer.
Never been to a Panasonic before.
Do the fronts come off on these machines?
And are they similar to LG machines?
This one is a bit of a pain. When you open the door there’s a trim panel that you have to remove that partially holds the front on. There’s screws behind the fascia in the middle and a couple at the bottom. The retaining springs for the door seal are a bit different as well.
